Hello, I'm in need of help with some AVI files. I have hours of video of my family durning the holidays and birthday parties, and was wondering how I would go about to make my AVI files to be able to play on a DVD player. I have a friend with a DVD-R burner, I have a few GB's of video and need help! I think I need to convert the AVI into a format and then burn them, but what program could I use, and then when I burn it will it just be put in the DVD player(not a computer dvd player) and start playing?Will someone point me in the correct direction please! Thank you!
As a suggestion, first this:
https://www.videohelp.com/tmpgencdvd.htm
then this:
https://www.videohelp.com/forum/userguides/172123.php
Others may have different views, but the above is what I use.
Good luck.Cole -
Hi zstarmaster,
This thread was started by someone wanting to do the same as you...
There are numerous answers, but all fall into one of two groups: "easy but may not get the quality" and "more involved but better quality more likely".There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
For pure simplicity, try VSO Software's DivXtoDVD. It's free, and it's easy as it gets. While you're there, download a copy of their CopyToDVD software and DivXtoDVD will automatically burn to DVD when it's done converting your AVI files.
Download both programs at http://www.vso-software.fr/download.htm
Just make you choose "Force NTSC" in the Standard dropdown box in DivXtoDVD to ensure it plays on your DVD player.
As daamon mentioned, there are many ways to do this. - The above solution falls in the "easy, but not the highest quality" category. Still, it's surefire and simple.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
