i used tmpge to make a mpg and if i try to burn a dvd with nero it wants recode it. what is the fastest way to put it on a dvd that plays in my dvd player?
https://www.videohelp.com/forum/viewtopic.php?t=248258
Same answer to a similar question
Cole -
Unless your DVD player can play RAW MPEGs burnt as data, you need to do the following:
Your MPEG must be DVD-compliant to start with.
Identify the specs of your file.
See What is DVD (top left) for DVD specs.
If your file is DVD-compliant, go ahead and author. If not, you need to re-encode it using an MPEG encoder.
Author using an authoring tool.
Burn using a burning tool.If in doubt, Google it.
Standard DVD in HD
By killerener99 in forum Newbie / General discussionsReplies: 15Last Post: 16th Apr 2009, 06:14 -
Standard quality/size for MPEG (*.mpg) videos?
By Ashman01 in forum Video ConversionReplies: 3Last Post: 22nd Feb 2009, 19:55 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
How to Burn standard DVD
By hmanhha in forum Newbie / General discussionsReplies: 5Last Post: 26th Feb 2008, 09:57 -
Pioneer DV-400V Any way to play standard MPG/MPEG-2 files from USB or disc?
By flobie11 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 2nd Feb 2008, 07:09
