Hi guys,
I'm trying to convert VOB to SVCD. Here is what I did:
.SmartRipper to rip the DVD
.DVD2AVI to create the d2v
.TooLame (2h) to create mp2
.TMPGEnc (2.01) to create tpr with SVCD/480x480/2300CBR
.VFAPI (1.04) to create the avi pointers
.VidualDub (1.4d) to create the avi movies
.TMPGEnc (2.01) to create m2v
.bbMPEG (1.24 beta 1 to mux m2v with 2 mp2(s)
I got error from bbMPEG: Cannot read input file
This error occur after bbMPEG done the whole process of Scanning A/V. At the end of scanning audio stream, I received a warning: Mux rate maybe too low for data rate, watch for PTS/DTS underflows. When bbMPEG tried to create the .mpg file, I got the error above.
Does anyone have any idea? The reason I use bbMPEG is (so far that I've known off) it is the only encoder that allows me to create a SVCD with 2 audio channels.
1. Did I do something wrong or missing some steps?
2. Is there another encoder (freeware) that can create SVCD with 2 audio channels?
Thanks for your information.
// BK
Results 1 to 1 of 1
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 18:25 -
Subtitle Creator error: Input string not in correct format
By kpic in forum SubtitleReplies: 6Last Post: 31st May 2013, 04:17 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59 -
Getting error: Could not initialize encoder. Probably invalid input.
By chrishallowell in forum AudioReplies: 0Last Post: 2nd Nov 2007, 00:29 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
