Hi people, first post.
I recently downloaded an avi from the web which is encoded with qpel. When I burn to DVD my player (Kiss 1000) is unable to play the movie because of the qpel (Is there some kind of firmware update to cure this?). I guess the only way to play it on that particular player is to remove the qpel somehow, ie. by re0encoding the avi to a different format. Is this the case? i have tried this using ffmpegx but cannot find a similar quality of video to my original. Time and size does not matter i just want to achieve the best possible quality.
I appreciate any advice, thanks
Qpel is incompatible with a lot of hardware and software players. KISS may or may not make a firmware upgrade that allows the KISS 1000 to read DivX with Qpel. All kind of recompressions are lossy, you cannot convert without loss. You could try to convert to SVCD og DVD.Originally Posted by kiemposan
How to reconvert an AVI with AutoGK, remove QPEL, GMC etc
By Baldrick in forum User guidesReplies: 35Last Post: 10th Jan 2010, 23:00 -
Philips DV624/37 AVI (XviD) Problems (Not QPEL/GMC)-could it be the codec?
By wingalls in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2008, 01:13 -
Removing Menu
By masterpkg in forum Authoring (DVD)Replies: 1Last Post: 27th Aug 2007, 05:05 -
xvid with QPEL
By ekyfetweky in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2007, 21:14 -
XviD: Qpel, GMC, Max consecutive B-VOPs, and N-VOP ??
By GangstaRap in forum Video ConversionReplies: 17Last Post: 20th May 2007, 04:59
