Does anyone know how to reset/over-ride the dvd region codes on a medion pc.
Any help gratefully received in advance?
Results 1 to 9 of 9
right click on the drive then properties...hardware tab...select you drive again then properties...should be under there. careful though you can only change the region so many times
Thats the problem as I have a large collection of both region 1 and 2 dvds
and I'm down to my last two changes. So I need to reste it if possible. -
do you know what the brand of your dvdrom or dvdburner is? some dvdrom and dvd burners are able to have region free setting with a firmware hack applied to them. do you have dvd region killer installed on your computer? dvd region killer will fool the operating system so you won't have message saying you can only change the region setting 5 times. but your dvd burner or dvdrom also must be region free in order to work with dvd region killer.
Yep, either use software from the Region Free Tools section in the Tools section, or find a hacked firmware for your drive.Originally Posted by glockjsIf in doubt, Google it.
or you can use DVD Region + CSS Free from www.dvdidle.com though it will cost you.
Either that or convert your movies to region free and leave the region of the player the same.
I bought that one a while ago. Even works for rippingOriginally Posted by waheed
It's worth buying.
We'll be right back after these messages from Binford!
LG HT503 Prom Option Default (region settings)
By RedSquirrel1983 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Jan 2011, 10:25 -
Mac DVD region settings
By harrymaciphone in forum MacReplies: 7Last Post: 19th Apr 2010, 10:43 -
Philips DVP642 How to restore my region settings
By dgreekman in forum DVD & Blu-ray PlayersReplies: 3Last Post: 15th Jan 2009, 10:16 -
Problem with Region settings
By paulgold in forum DVD RippingReplies: 11Last Post: 18th Apr 2008, 21:47 -
Region settings help
By ian curtis in forum Software PlayingReplies: 6Last Post: 7th Dec 2007, 07:19
