the files play, but when I right click on it, after a long wait the window crashes, adn I get a send in report dialog box to microsoft saying it crashed and had to shut down.
I don't know what the deal is... the media file itself can be played if left click as usual, but when I right click on some of these files it crashes the windows.
I tried...
to copy to a different folder... copy was successful, but any problems came with the copied version.
Tried to repropagate the rights (windows xp) but this was not an issue.
Something is crashes... I just don't know what is.
Can you help with some ideas?
Thanks!
pcexpress-guy
pcexpress-guy
I had this problem when I had an old version of Divx 5.2.1 installed. I uninstalled Divx....downloaded the latest build and re-installed Divx and the problem went away.
Here is something you might want to look at.
http://forums.divx.com/viewtopic.php?topic=60461&forum=24
The latest build of Divx fixes this problem. -
You know, I don't have divx installed
by installing it, would it fix it.That would be cool.
There is something going on with this desktop as I was able (over a network) access the files, and right click it and use it as standard.
I wonder if some of the right click things I added such as winace, might be crashing this?
Can I disable stuff on the right click menu from opening? TooL?
Thanks!pcexpress-guy -
Get SHELLEXVIEW....
http://www.nirsoft.net/utils/shexview.html
...which allows you to disable items in the right click context menu. From personal experience sometimes this causes an Explorer crash and disabling the item fixes it.
The items you are interested in, in the ShellExView window are labelled Context Menu under the heading Type. Left click Type to sort, then select and right-click an item and choose Disable.
Try disabling everything that looks like an add-in and, if problem is fixed, then re-enable one at a time to establish cause of problem. -
I think the files are good. The file over the network on another computer (clean install) can access these files. Which makes me think some right click handler that was added after install on the problem machine is at fault.
So... not sure how to reset the handlers.. but this tool may be helpful indeed.
ThankS!pcexpress-guy -
See if this helps:
https://www.videohelp.com/forum/viewtopic.php?t=245068&highlight= -
I've got a similar, but not as severe problem. Whenever I right click on a video file my monitor blacks out for a second and then comes back. I've posted this on a few forums and never had any luck with an explanation or fix. I'm wondering if it is related to yours. I'm using xp, maybe instead of crashing, it recovers itself in my case...This only happens with video files, no other kind.
Need help for Window/VLC Media Player
By Neil_2004 in forum Video Streaming DownloadingReplies: 2Last Post: 27th Feb 2012, 19:05 -
Window Media Center Help
By vcd4me in forum Capturing and VCRReplies: 4Last Post: 14th May 2011, 16:18 -
window media player does not work
By romanstopme in forum ComputerReplies: 8Last Post: 6th Dec 2008, 12:21 -
Window Media Encoder Can't find codecs
By Ensign in forum Video ConversionReplies: 2Last Post: 18th Jul 2008, 11:33 -
Window Media Player and TV
By BobV in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2008, 16:34
