Need a recommedation for software that will go to and from both formats. Can you recommend any thing? I don't see any in the tools section. need a simple app that works.
Thanks!
pcexpress-guy
Cleaner XL
thanks! Do you have a URL link for cleaner xL? i can only find derivative sites? Who makes it? also the tools section here, I coudn't find it. (even though google says there is something in the tools section)
Maybe the site I found is down? Is this it?
http://www4.discreet.com/company/company.php?id=588
I only get the top of web page header... i see sql error... but not sure if this is it.
thanks!pcexpress-guy -
http://www4.discreet.com/cleanerxl/
... but the site looks screwed right now.
That's what I used at a friend's house, Cleaner 5 actually, the time I made some WMA files. I forget what else here does it.
Search. I think something free has to exist.Want my help? Ask here! (not via PM!)
Would it be possiable to increase DB in the conversion? some speech files are too low in volume... is there a software tool that will do that all in one?
Thanks!pcexpress-guy
wma to mp3
By rjc7394 in forum AudioReplies: 5Last Post: 14th Sep 2010, 15:00 -
Best FREE software to change a WMA file to an MP3??
By UmmAddan in forum AudioReplies: 17Last Post: 20th Jun 2009, 18:52 -
Help with MOD to mp3/wma
By Bluntz11 in forum AudioReplies: 10Last Post: 14th Apr 2009, 21:12 -
Is it possible to convert Mp3 to wma?
By t_jay17 in forum AudioReplies: 8Last Post: 17th Feb 2009, 17:32 -
wma to mp3
By rjc7394 in forum AudioReplies: 0Last Post: 8th Jul 2007, 20:28
