OK I'm using IE with sp2, it was my assumption that it blocks all pop-ups. I've noticed it doesn't block those pop-ups that are embedded in the page such as ones that can be found here: http://p206.ezboard.com/bundergroundminers There is another pop-up on this site that IE sucessfully blocks. Makes sense you can't block the embedded one since it's part of the code in the page.
....but if I go here to one of the local newspaper sites http://www.citizensvoice.com there's a regular pop-up that sucessfully gets thru in a new window.... BTW this site sucks as far as pop-ups go. If you didn't block them at all there would be about 3 per click..... Google pop-up blocker fails too for the one that gets thru IE. So what's up anyone know? I think it has something to do with the link structure.
Edit: hmmmmmm, many of the links lead offsite, here's their guestbook. Simply clicking the form entry "Your Name" at the bottom of the page brings up a pop-up..... http://www.zwire.com/site/community.cfm?brd=2259
Edit2: LOL I can't even put my name, it reactivates the pop-up removing the cursor from the field...... What jackasses.
Results 1 to 19 of 19
Don't have an answer, but if we pay the 535 guys in Washington D.C. to pass a bill to make pop ups illegal, you think this might go away?
Hello. -
I don't get a popup at all. SP1, IE6. ????
Don't think you could do that, there's no one forcing you to go to the website that serves the pop-ups..... I would disagree with that anyway because why should anyone delegate to me how I design my site providing it doesn't contain malicious content. If there such a nuisance then I just won't go there such as the site I linked to above. I was bitten by this anti-ad thing on my site. Norton ad blocker was blocking some of my site content just because of the folder name which is complete bullshit since it was legitimate no-ad content.
Anyhow upon further investigation, i was incorrect. It doesn't pop-up on the first page load but when you click anywhere on the page....... dirty bastards.Still thought that was not possible with IE and SP2...you get LS when you click on anything.?
I think it's your computer. I get nothing here.
Sounds like you've got spyware. This site doesn't have any pop-ups.
Originally Posted by pacmania_2001
I get the pop-up on there parent site too.... www.nepanews.com .... now I'm baffled.... -
Originally Posted by thecoalman
I'm getting one that's getting through besides the two IE blocks..... I think I might know why, I have MS VM installed for a piece of software that requires it.... Could be the culprit.
Still nothing. Odd. I didn't think Norton, or Spybot dd anything to pop-ups. I never get them. No blocker running either, it's turned off.
I use Firefox to keep out self-installing crapware. I use IE here, trusted site. "surfing" I use FF.
Using IE 6 w/ XP SP2, at the underground coal site, I got a pop-up displayed (the embedded one) and one blocked. I turned my pop-op blocker settings up to high, and both were blocked. At the newspaper site, the pop-up was blocked on both medium and high settings.
If in doubt, Google it. -
I have found that my IE also leaked pop-ups. The blocker just doesn't work right.
Firefox blocks everything unless I explicitly tell it that it should allow it.
Try Firefox. -
I've got sp2, but use the google toolbar and not the popup blocker from windows. I like the running tally of how many it's blocked. Almost to 3,000!!!
What is this pop up on Vhelp ?
By Noahtuck in forum FeedbackReplies: 3Last Post: 18th Aug 2010, 15:08 -
Spyware / Adware / Pop-up HELP!!!!
By DVWannaB in forum ComputerReplies: 5Last Post: 13th Oct 2008, 19:16 -
Pop up doesn't go away
By jyeh74 in forum ComputerReplies: 20Last Post: 22nd Sep 2008, 04:54 -
Pop-up video
By uniks in forum Newbie / General discussionsReplies: 19Last Post: 29th Aug 2008, 21:44 -
A pop up
By imkool in forum Software PlayingReplies: 1Last Post: 19th Feb 2008, 12:11
