The project I'm trying to convert keeps crashing , but at different points . So far at 19 % , 29 % , and 32 % . The error message is -
write error occured at address 03E35027 of module 'sfmpgdec.dll' with C0850000
Having looked through the guides I've tried to change the directshow codec reader priority but without any luck . Was this only an option on earlier versions of TMPGenc ? There are no obvious "environmrntal settings" under options , and even though I've found directshow codec under preferences there is no option to increase it's priority . It's just a ticked box .
Is there anything I can do to solve this problem ? I've run the file through Vdub_mp3_freeze and not found any bad frames . Frankly I'm stuck .
Results 1 to 1 of 1
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
