Hello all. I am kinda new to the vcd world. Am wondering something.
I have an mpeg-1 file. I put it on a cd-r with Nero, and played in in my dvd recorder. The picture is very fuzzy.
Can someone recommend any software that will help me shrink the dimensions of the file? I want the picture more clearer which of course means messing with the dimensions of the file and making it smaller.
thanks for any help you can give me.
Rick
snafu1@yahoo.com
Well, start by reading What is VCD? (top left). Anything you author as VCD has to meet VCD standards, otherwise it's known as an XVCD.
If you alter the frame size (I assume this is what you mean when you say dimensions), your player must be able to handle this change (not all can play non-standard resolutions. If you make the frame size smaller, then your DVD Player will have to resize it more anyway to fill your TV screen, which IMO will make it look even worse than it currently is.
The first rule of video applies throughout - if you put garbage in, you're always gonna get garbage out.If in doubt, Google it.
Issues with Dimensions on Export
By jherzog in forum MacReplies: 3Last Post: 19th Jul 2010, 15:29 -
What's the Dimensions for a Title Screen?
By blaqlion22 in forum Authoring (DVD)Replies: 2Last Post: 28th Sep 2009, 00:13 -
x264 - new pass with different dimensions, is it OK?
By kurbads in forum Video ConversionReplies: 16Last Post: 5th Sep 2009, 06:57 -
Photo Frame, and figuring out best dimensions
By snafubaby in forum Portable VideoReplies: 2Last Post: 21st Dec 2008, 03:37 -
How to Retrieve WMV Dimensions/Bitrate?
By kenny782 in forum ProgrammingReplies: 7Last Post: 3rd Nov 2008, 19:01
