hi all
i'm trying to convert a dvd to some vcd's
i ran easyvcd, followed the sefy guide
tried vcd and xvcd, with whatever standard options pretty much
what ever it let me do, that seemed right
it seemed to be going ok
but when it was running tmpeg
it returned this message
d2v cannot open, or not support (something like that)
and it says bin/cue files are in the output dir
i looked in the directory where the files were meant to output to
and there were these .vob files that were like 1gb big and stuff
but when i clicked ok on the message dialog
those files disappeared, and there were no bin/cue files (there were never any)
using windows xp pro, p4 2.4GHz 768 mb ram, output device 80gb hdd, about 20% used
don't know if this is a cause, but my system partition is G:\ not c:\
programs are installed on G:\, even though i prefer them to be on a different partition
is there another way to do this?
something straightforward, as i don't want to do anything fancy
just want to convert my cousin's wedding dvd to vcd for a relative who can't view it
thanks
dave
That's definitely your issue right there.Originally Posted by dragonBoy
I had the same problems when I set up a dual boot system and had G: as my OS drive. EazyVCD requires some files to be on C Drive, so if you can't arrange for a C Drive install for EasyVCD then you're SOL with that program unfortunately
I had win98 running off my C Drive, so I simply installed it on there and I could still run it without any issues whatsoever when in XP.If in doubt, Google it. -
hey mate, thanks for that
well, i can't change os's
i'll have to see what other methods i can use
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
