Hi all,
Ok, I need a little help here. It's late so bear with me...
If I calculate the bitrate to be 6000 for a particular AVI I want to encode to mpeg2 but want to use VBR, not CBR; what do I put for the Max/Avg/Min? 6000 across the board? That doesn't sound logical, but I don't want to "waste" space. By that I mean, if I set the bitrate to 8000 Max/ 6000 Avg / 4000 Min, will that "fill" the DVD or come in at like 2GB? Conversly, I don't want a 5GB file either. I know using CBR the calculator is going to give me the correct bit rate to get me close to 4.37GB everytime. Basically, if you were in the situation described above, what would your settings be and why?
I searched for this topic (honest I did) and didn't come up with any answers. Forgive me if I looked in the wrong place...
Thanks in advance....
Results 1 to 30 of 49
Use the bitrate calculator on this site.
Whatever you calculate, put as the Avg. I normally put the Max to 9000, but according to DVD specs you can go up to 10080 minus your audio bitrate and still be DVD-compliant (DVD specs say that 10.08Mbps is the max combined bitrate). That said, some players have been said to "choke" on bitrates above 8000 or so, so it's a bit of trial and error in that regard to see what your player plays/chokes on. For Min, I normally use 1000, but other people here report great success with using 0.Originally Posted by joecav
The VideoHelp.com Bitrate Calculator gives you the value to hit the size 4480MB, no more, no less. So set your Avg to the calculated value (in this instance 6000), and then I'd use Max 9000 and Min 1000 in addition to this.Originally Posted by joecavIf in doubt, Google it. -
I do use the calc on this site. Pls show me where it tells you what to put in for the Max/min values...Originally Posted by lordsmurf
I question the logic or rationale of it for VBR. I guess if you set the Avg to what you calculate the bitrate to be, the max and min will have no effect on the file size? Obviously setting the Max to more than 6000 and the min to less than 6000, from the 1st example...is that correct?
@ Lordsmurf
I know you know your video stuff like the back of your hand and I obviously would never question your expertise, but when I posted this I was hoping not to get a smug response from you. I'm not sure if you realise it or not, or even care, but people who look to this site for help will do so less frequently if they know they will be made to feel less than smart when they post. I mean really, how much help do you think your answer would give me considering what I asked? -
Correct. Min and Max have no effect on the filesize whatsoever - they tell the encoder the outer limits (low and high, obviously) that it can act within in order to finish with an average bitrate of whatever you've calculated and put in as your average. But, they can have amassive effect on the final quality of your encode. So the bitrate calculator is still very much required. If you want one to tell you Max and Min also, try this one.Originally Posted by joecav
Whoa!Originally Posted by joecav
Grain of salt, dude. He was just trying to help
If you've been around here for any period of time and seen the number of people that require tissues held for them when they sneeze, you'll know why some responses are "dumbed down" - it's sometimes hard to judge the relative experience/knowledge base that the OP has at their disposal.If in doubt, Google it. -
I usually set the MIN at 2000kbps and the MAX at 8000kbps and then the bitrate calculator will give you the AVG.
In fact with an AVG of 6000kbps I would use a MIN of 2500kbps
- John "FulciLives" Coleman
P.S.
If you are using PCM audio then I would use a MAX of 7500kbps for the VIDEO bitrate"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Thank you both for the knowledge transfer I was looking for. BTW I use AC-3, not PCM.
As far as me needing to take a grain of salt, I stand by what I said in my first response. Even if I was a complete noob, the first answer I got wouldn't help anyone. I was just letting LS know that sometimes his posts come across as condescending. Whether he meant it as such, I don't know.
Again, I thank you guys for the help. -
It's like jim said. First you give an obvious answers. If that doesn't work, they come back for more. Then you hit in-depth. It's what happened here.
For VBR ... it's simple ... you guess!
Use the calc as the average.
Then the minimum can be 0 (or 1000 for TMPG),
and then spike it up to the max for that res.
720x480 max = 8000/9000
352x480 max = 3500/5000
Pick a number in there for your res.
If unsure, guess low. Under is not bad. Over is bad.Want my help? Ask here! (not via PM!)
It is bad to set the MIN too low and 1000kbps is too low in my opinion.
With TMPGEnc Plus you don't want to go below 2000kbps if you can help it. I've heard that CCE works better at a lower bitrate but I still wouldn't go below 2000kbps or at the very least keep it at 1000kbps (for CCE).
For Half D1, 1000 is almost getting to be too high.
The "cherry" spot for MPEG is about 1500-2500, just look at DSS/DVB transmissions. You want to allow that to be hit if the encoder so desires it.Want my help? Ask here! (not via PM!)
Different encoders will respond differently.
Numerous tests showed me that CCE, for instance, will consistantly undershoot the AVG value unless a fairly high MAX value was applied. It seemed to smooth out the spikes in bitrate.
TMPGenc seemed to need a somewhat lower MAX value, it would get more extreme in the spikes and consistently overshoot the desired AVG.
MMC seems to work best when the MIN-MAX-AVG range was very narrow, 500-1000 for each gap. MMC tended to have severe bitrate "valleys" resulting in pixelation. -
For Half-D1, why VBR anyway? CQ does the job excellently. Crisp & clear!Originally Posted by lordsmurf
CQ IS VBR. Its just one pass VBR with no way of guaranteeing the final file size.Originally Posted by NamPla
Don't get me wrong, Tmpgenc's CQ mode produces excellent quality results (IMHO) but has a big drawback of not being able to know the final filesize in advance. So when trying to squeeze max play time onto a disk, irrespective of your resolution, it can be hit and miss. -
I have some VHS tapes I converted that were short enough that if I was able to set the bitrate to 4500kpbs or higher I would do a CBR at Half D1 resolution.Originally Posted by NamPla
The Half D1 resolution seems to hit MAX bitrate at about 5000kbps so anything close to or above that only needs a CBR encode.
No surprise that this thread is generating as many different opinions as there are posts
It's like asking "what's the best car to buy?"
IMHO, CBR is obsolete. It died with VCD. Enter intelligent encoding and VBR. Why run your bitrate up high enough to not get macro blocks in flashing or fire scenes, and use the same screaming high bitrate for two talking heads sitting still at a table?
FWIW, for full D1 I've refined my settings after about 2500 feature-length captures and what works for me is 5000 average, 9800 max. No setting for minimum
I'm willing to drop the average to 4500 rarely, when multiple discs are not an option. Otherwise I don't drop that, but rather capture in two parts and preserve the quality. I've had to redo far too many DVDs (several hundred, from my noob days) because of dropping the average too low, and I have learned my lesson the hard way
@ joecav
I'd like to add a little snippet of info based on when I first set out doing VBR having got CBR encoding under my belt.
I read this guide, paying close attention to the section on VBR settings. In there, it says to have a Min = 2,000 - so I figured I'd go for 4,000 "just to be safe" and thought "higher was better".Turns out (no surprise), I was wrong. Here's why...
The Min and Max are there, primarily, to set the lower and upper limits for the bitrate that the encoder can use. Easy. But, here's the smart bit that I didn't see:
By Having a lower bitrate, it means that the encoder can go way low when it needs to - i.e. black screen (e.g. between scenes), low / no movement scenes (people talking) etc. This leaves more bitrate to be used when needed (i.e. by high bitrate scenes).
Conversely, this means that the encoder can then go way high when it's needed. And more often because bitrate hasn't been used in the lower bitrate scenes.
The two together will most likely balance and the average (as long as it's reasonable, i.e. not too close to either extreme) will be achieved (or thereabouts).
In short, greater (sensible / within spec) extremes of Max and Min means that the quality in the picture is achieved when and where it's needed.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
@daamon
Great insight, I GET IT NOW!!!
Yahoo!
Thanks again guys... -
I felt like that when I had the same thing explained to me! I think it was bugster who enlightened me. Not sure...
Carpe diem.
LOL....I just did my 1st VBR conversion! Here is a comparison...please tell me it's "worth it"...
A 2.5 hr AVI, if done with CBR = 3 hrs
VBR 2 pass = 12.5 hrs!!
Holy frijoles!!! -
Well...I am using Vegas 5....have been for over a year. I have converted about 20 Steeler games to DVD, each one about 2-2.5 hrs in time and CBR takes about 2.5-3 hrs.
I use the DVD architect template (no audio) and plugged in the VBR values...I did change the size to half D1. Maybe thats why it's taking so long. But I started it last night and it ran overnight, took a little over 12 hrs. -
WOW!!!
jimmalenko's right... Have you changed any settings? i.e. included (additional) filters, set a higher "Motion Search Estimate" (or whatever it's called - can never remember), left some other software running when not previously (particularly CPU hungry stuff) etc...
EDIT: Simultaneous posting... Keep everything the same as when you were doing CBR, just change the VBR settings for a true comparison. "everything" includes any apps that were or weren't running etc.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Ahhh, I see. I figured it was that. Thanks again to everyone for the comments and help.
What Capmaster said above is so true, and I agree with him on them
These days, I prefer CBR at 9000 bitrates. I'm refining my process
still. But, CQ offers a lot as well, to those that don't want CBR
in their process.
Some encodes work better w/ different MODE settings than others.
For instance, CBR does better on Interlace-only sources (such as CAM
footage) vs. VBR. Because (IMHO) VBR does not help enough
when the scene is very fast. And, I've come to beleive that as long
as you think in tirms of 60 minutes to a DVD (home footage) that's
the goal. And, CBR at 9000 seems to closely make it. (I'm having
trouble hitting that mark - fitting 60 min on a DVD disk w/ CBR, but
I suspect I'll figure it out) .. plus, w/ CBR (and home footage) you
will not have to wait those long hours.
One more point about footage (even though it was not mentioned above)
If we all used a tripod in our video footaging, we'd have less worrys
w/ Bitrate settings
..The only reason why CAM footage is soo
probablem matic, is because many still take footage by hand.. instead
of a tripod. ..END OT.
* jimmalenko wrote:
Not so. (read below for in-depth) ...As bugster said, if hitting a target size is important (and it is to me ) then CQ is not really appropriate.
In short.. a one hour program (be it TV or CAM footage) and CQ, WILL
fit on a DVD disk
Really !!!
What is needed at the moment, if a fine-tuned CQ recepie
Because CQ is not CBR, there is a *greater* chance of fitting a 1 hour
tv program/CAM footage on a single DVD disk. Yes. Anyways.
And, absolutely NO FILTERING is needed ! !
Here's another great reason/advantage to using CQ (TMPG)
in your DVD projects.. (assuming that is your final goal) ...
* Speed
* Quality
Ok. Lets say, you have a 90 ~ 120 min movie, but you don't want to wait
the hours of multi-pass encode (tipically 2 pass) and need the speed (as
we all do) and *quality* thereof..
You could do it w/ 2-pass (w/ semi gaurantee of quality) *or* you could
go the CQ route, and go for broke.. because your final destination is DVD
..but half the time. CQ offers that.
You don't have to worry about space, fitting on a DVD disk, because the
chances of a 2 hour movie (using CQ) not fitting on a single dvd disk is
almost nil. And, if your movie is 60 minutes, you have a MUCH greater
chance that you'll come out winning no matter what. Even if you have plenty
of dvd disk space left over. (next time, calculate your bitrate / CQ values
better w/ a little extra nudge) Before you know it, you'll do winging it
w/ a blind-fold over your eyes
If you use VBR (2-pass) you're gonna be waiting. Plain and simple. Quality ?
Well, I believe that there is just too much hype w/ multi-pass encodes.
CQ offers very good quality. It suffers one draw back. And that is, knowing
that final outcome. That is, if your source is greater than 90 or minutes,
and you want specific numbers in your final projects.
With CQ, you can gain speed and have quality at the same time, and w/ a little
practice, be able to juggle the CQ values needed for a good DVD encode project.
Ok. Scerio.. something to think about ...
Lets say, you want to capture and encode a 60 minute movie. You might get away
with it using CBR and 9000 as your bitrate (though I have doubts that it will
succeed and fit on a single DVD) .. However, lets continue..
So you capture this 60 minute program, and you choose a CQ mode as your encode.
I like quality, so I"ll set my params as:
* min: 4000 ~ 6000
* max: 9000
* CQ: 74
*note, I've never had a problem with this, but there is always a first. But
as I said (as a hint/nudge above) you learn these things as you go, and get
better at it, till you can do w/ blind-folds on.
The above is not etched in stone. It's something I was working (though I stopped,
due to other events and things)
Lets continue..
Now the encode is complete. You find that your 60 minute tv programs' encode
had left you with plenty of space left over. Well, thats something for you
to work with later, in your next CQ Encode project
.. but,
The first thing you *could* do, is verify the level of quality.
* Was it good ?
* Was it poor ?
* Did you conclude you could have raised the CQ value a bit, (or bitrates) ??
These are things you can play with, and gain the necessary knowlege (next time)
till you become better at it.
But, so what.. you had plenty more space left over on your DVD disk. Your
goal was fitting a 60 minute program on a DVD disk. You succeeded. You can
play a little w/ the settings and get better at filling the disk (if thats
at all important to you) but its not necessary, if A) the quality is there,
and B) you met your goal (that being, that you didn't go over-board of your
disk space)
There are all kinds of scenarios w/ CQ encodes. The above was *just one*
example. But, think about it for a moment. What do you really want ?
My point above, w/ respect to CQ, is that if you are growing tired of the long
waits for multi-pass encodes, and (after factoring "dvd" specifics) your goal
is DVD, then it might not be such a bad idea to learn this mode of encoding
that TMPG has to offer. Actually, it's CQ mode is very good. You just have
to *spend* the time to learn and feel for it. But, that's only if you are
willing to learn something new.. Otherwise, you're best to just stick with
multi-pass VBR and wait, and wait, and wait, and wait (well, you get the idea)
So, again I ask... think about it for a moment. What do you really want ?
CQ offers as much as VBR, but w/ one missing advantage. And, I just explained
above, why even that limitation is nil. Anyways.
Don't forget, I'm speaking for TMPGenc w/ regards to CQ and the above cents
worth.
The above was my many cents worth,
-vhelp -
Of course it fits. It is physically impossible to make a 1 hr compliant DVD that won't fit on a DVD5. Max out the video bitrate and max out the audio bitrate and there will still be room on the disk. This is not evidence that CQ is viable where target size prediction is necessary, it is simply evidence that the DVD standard was intended to be used for more then just 1 hr of content per disk.Originally Posted by vhelp
If you've only got 1hr of content it really doesn't matter whether you use CQ, CBR, or VBR because the efficiency of bitrate allocation is pointless when filesize is of no concern. I don't see any reason to use anything other then CBR in this case.
But when encoding enough footage that bitrate allocation is a concern, multi pass VBR is the safe bet. You can be sure that you will hit your target size exactly, and you can generally be assured that the quality should reach the point of diminishing returns at that bitrate with that encoder. With 1-pass VBR, you can also reach this same point of diminishing returns, and in a much shorter period of time. However it requires some pre-encode quality tests and there is the risk that you will stray enough from either your target size or target quantization level that you will have to go back and do a second pass. Personally, I'd rather just set it to do 2 passes from the start and leave it alone. Yes it takes longer but it requires less micromanagement and ultimatley less of my time. If you've got a slower pc your priorities will be different but personally I find 1 pass encoding useless unless you've got an undecided amount of content to encode. Then you can just shoot for the maximum Q (higher Q=lower quality) you can live with and fit as much content as you can.
cbr to vbr
By dynamix1 in forum AudioReplies: 1Last Post: 17th Mar 2009, 15:12 -
CBR vs VBR
By prl in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2009, 19:48 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
VBR, ABR and CBR ??
By moiz in forum AudioReplies: 11Last Post: 19th Oct 2008, 18:22 -
VBR or CBR?
By dizzie in forum ffmpegX general discussionReplies: 1Last Post: 29th Jun 2007, 15:28
