I just have a fairly simple (I hope) question. I have a DVD with what I think is called a "hard letterbox". It's widescreen, but it has black bars on the top and bottom, so it's really fullscreen. I want to change it to "real" widescreen.
I just want to crop the video and cut the black bars off so it will look decent and fill the whole screen when viewed on a widescreen portable dvd player. Is there a simple way to do this, and not loose any quality?
It's a DVD-5, so it won't need any compressing, and it has no menus.
I've searched the forums and guides, but I didn't really come up with anything. Any suggestions?
This would entail re-encoding the video (some quality will be lost while re-sizing).
You will have to re-encode as said by live4ever.
If it is NTSC you cut 60 from the top and 60 from the bottom then resize to 720x480 ... I should point out this is if the DVD is 720x480 to begin with as it should be if it is a commercial NTSC DVD.
If it is PAL you cut 72 from the top and 72 from the bottom then resize to 720x576 ... I should point out this is if the DVD is 720x576 to begin with as it should be if it is a commercial PAL DVD.
That will convert 4:3 WS into 16x9 WS
Try DVD Rebuilder (freeware, although you must have an encoder). It has an option for recoding 4:3 letterbox to 16:9. Once set up, it's very easy to use.
wwaag -
Oh, cool! I never thought of trying Rebuilder for this project. I've used Rebuilder on some of my other backups, so I already have it installed and everything! I'll try that first, I'm anxious to see how it turns out.
Thanks, and I'll post back with my results when I get it done!
Can I remove black bars (top and bottom) when backing up my dvd's?
By jammiev in forum DVD RippingReplies: 10Last Post: 17th Jan 2012, 13:19 -
White letterbox bars on menu in DVDLab Pro
By FaterCarras in forum Authoring (DVD)Replies: 8Last Post: 6th Sep 2010, 03:19 -
Nero Vision 8 letterbox bars too bright
By Davel23 in forum Video ConversionReplies: 3Last Post: 17th Feb 2008, 01:49 -
Best tool to remove black bars?
By jedi34567 in forum Video ConversionReplies: 7Last Post: 15th Jan 2008, 10:44 -
How do I crop vertical bars? (widescreen to fullscreen)
By Salva Veritate in forum EditingReplies: 1Last Post: 6th Dec 2007, 22:18
