I was wondering, I converted an SVCD to VCD using the tutorial in the conversion section, but I was wondering when i converted it, it was half the size, I wouldnt mind converting it to the same size, how can I improve the quality when coverting to VCD, plz, thnxs
Why buy, when its supplied
you could make it a non standard VCD (or xVCD) by raising the bitrate above 1150
that will improve the quality but it will never be _better_ than the source -- if your source is a bit fuzzy or has background noise then you can keep the bitrate the same and apply some filters
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 10:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 08:34 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27
