When I use Gspot to check a video it says I mssing the Xvid.ax in c:\windows\system32
Does anyone know where I can download it or restore it, or if I even need it at all?
Thank you
At a guess I'd say it is a file associated with the XviD codec. To fix, it should as simple as re-installing an XviD codec. You'll only need it you play or convert XviD files on your computer.
If in doubt, Google it. -
yes I reinstalled Xvid, but it says it can't find the file on my computer. All the movies play just fine, just wondering if this is a critical file that needs recovering??
Many thanks for your help -
It is XviD's dshow decoder. If files play fine without it, then something else like ffdshow is being used to decode. If you want just xvid.ax you can grab it here: http://celticdruid.no-ip.com/xvid/
The 7-zip files contain just the XviD files; xvid.ax, xvidvfw.dll and xvidcore.dll.
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 14:18 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 19:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 16:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47
