How to fix the sync of a mpa & mpv file? The audio is fine at the beginning, but goes out of sync later. The original Mpeg2 runs ok.
i have that same problem and somewhat have a workaround. i guess other people have used it as well.
try using VirtualDubMod and demux both audio and video streams to separate files then use your usual encoder to make your mpa and mpv files. my sources turn out fine and in sync after this
hope it helps -
Try demultiplexing it with Demux rather than the program you were using. You can find demux here at Ted Rossin's site:How to fix the sync of a mpa & mpv file? The audio is fine at the beginning, but goes out of sync later. The original Mpeg2 runs ok.
http://www.geocities.com/Ted_Rossin/tools/Video/Video.html
Rip and restore original mpeg2 file?
By lattedfw in forum DVD RippingReplies: 3Last Post: 16th Apr 2012, 00:24 -
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
How does one process mpa and mpv files?
By mysts in forum Authoring (DVD)Replies: 2Last Post: 11th May 2011, 14:30 -
MPV and MPA out of sync with Media Player Classic
By Talayero in forum Newbie / General discussionsReplies: 2Last Post: 13th Mar 2009, 09:34 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48
