Hello friends, again I ask your technical support.
In the next future, I have to transfer about 20 Gb from an Pata Hd (with win98 installed) of an old PC in a new drive with Xp home installed. Connecting this disk as Pri Slave, I will try to load Win without doing anything else.
But then ? Do you think I'll found immediately the drive clicking the icon My Computer ? Or I'll found some probles like partitions...
Thanks for help!
Minds are like parachutes. They only function when they are open !
You should have No problems. The old HD will show up as drive D: or E: on your new computer.
"Quality is cool, but don't forget... Content is King!" -
Thanks a lot Soopafresh,
Yesterday I tried to do what I said and I had no problem !Minds are like parachutes. They only function when they are open ! -
Xp also has a files and settings tranfer wizard, if you chose to go that route.
Which one bazooka ?
START >> PROGRAMS >> ACCESSORIES >> SYSTEM TOOLS >> files and settings tranfer wizardOriginally Posted by Italic
Skype data transfer
By alintatoc in forum ComputerReplies: 3Last Post: 19th Dec 2011, 00:49 -
German Scientists Transfer 700 DVDs of Data in One Second
By hech54 in forum ComputerReplies: 2Last Post: 25th May 2011, 12:45 -
Data transfer speeds
By Sybull27 in forum ComputerReplies: 10Last Post: 26th Apr 2010, 08:12 -
Slow Data Transfer from Slave to Master
By jollyjohn in forum ComputerReplies: 15Last Post: 9th Oct 2009, 00:48 -
How do I transfer data into dvd.
By millyvanilly in forum Authoring (DVD)Replies: 8Last Post: 24th Jan 2009, 21:34
