I was checking out the philips trouble shooting page for the philips 642 which i hope to get later on this month. I know of programs like gspot to check how the divx file was encoded but the philips help section mentions NOTE: The player does not support GMC and Q-pel. It only supports DivX 4.x and DivX 5.x files recorded in 'Home theater' mode.
So how can you tell if it was encoded in Home Theater mode?
According to DivX 5.1.1 Home Theater Quality is:
Recommended max resolution: 720 x 480 @ 30 fps, 720 x 576 @ 25 fps
Maximum MB per second : 40500
Maximum average bitrate : 4000kbps
B Frames : Allowed
Interlace : Allowed
Audio Must Be MP3 format
Too bad DivX doesn't tell us what the MINIMUM resolutions are to play on DivX DVD players. -
I am trying to burn a movie with 4,278,230KB and as a result I have lost 4 rewritables with this new dual layer 16x writer. It starts to burn and then it fails afte about 80% I was just wondering could that be the root of my problem will I have to DVD shrink it. The error message has also been Medium error.
Sometimes I use my dvd recorder to format the disc in DVD Video mode, should that matter at all? The discs I am using are DVD-RW/R. -
lingoguysw5 - start a new thread if you have a question
InterVideo Home Theater
By aadis in forum Capturing and VCRReplies: 8Last Post: 4th Feb 2011, 03:55 -
Home Theater
By Al27 in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2011, 18:37 -
When converting VIDEO_TS to DivX, why is only the first file encoded?
By SheerGold in forum ffmpegX general discussionReplies: 5Last Post: 10th May 2009, 12:41 -
Command line method to convert MPEG-2 to Divx Home Theater Profile
By CLIjunkie in forum Video ConversionReplies: 15Last Post: 6th May 2008, 22:22 -
FASTEST WAY: Divx 1024x576 to Divx "Home Theater"?
By GrayStrickland in forum Video ConversionReplies: 7Last Post: 5th Feb 2008, 22:03
