  1. Everytime I get my hands on a video I have to figure out what program to use to get it on CD or DVD. I usually just end up confused. Is there a guide that tells what you should do with certain types of video files to put them on CD or DVD?
    THanks.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    As I mentioned in this thread, this guide should be able to convert most filetypes to DVD. this guide will do same if you want to create an XVCD. With a bit of tweaking, you can also make it make XSVCDs.
    If in doubt, Google it.
