  1. I have a 700 MB AVI(XVID). I tried to burn it to SVCD with Nero but the program said it was waaaaay more than a CD could hold. Then I tried to convert it to DVD with Nero but it was still huuuuuge.
    Am I supposed to do something to make it fit on a CD or DVD?
    Thanks.
  2. Banned
    Sep 2004
    Inner Circle of Thought
    With the svcd mode, it can hold about 50 minutes of audio and video.
    If it is over that timelength, you will either have to use a nonstandard encoding factor or split it up onto 2 or three cd's.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    This guide should be able to convert most filetypes to DVD. This guide will do same if you want to create an XVCD. With a bit of tweaking, you can also make it make XSVCDs.
    If in doubt, Google it.
