  1. Got A question is there a program/software that u can load/run a movie thru where it can automatically detect if the movie is out of sync with the audio and tell u where in the file its out of sync
    Im askin this because cause im always having out of sync problems I usually only preview the movie on my computer after i convert it to vcd and alot of the times i miss certain parts or dont notice if its out of sync and i dont find out till i burn the movie and am ready to watch it on my dvd player
    so what im askin is there some kind of program where u can scan a movie thru it and it can detect and mark where the audio goes out of sync with the video or something similar to that
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'm not aware of any software that can automatically do it.
    One way to avoid it is to not bother with downloaded material. I have found no such problems whatsoever when dealing with DVD sources or material I've created myself. It's only ever been downloaded material that has caused any synch issues for me.
    Just a thought
    If in doubt, Google it.
