Ok so I have a folder with like 200 files and I want to copy the names of all these files onto notepad or word and print it. I'm using Windows XP btw. Anyways, whenever I go to copy it, it is basically asking me to copy the file itself and not the file name. I only want the name of these 200 files. I know I could just click rename and copy and paste each file but I'd rather have a way to do a bulk copy and paste of the names. Is there any way to do this? I've been trying to figure this out for the past few days. Any help would be greatly appreciated. Thanks in advance![]()
Results 1 to 10 of 10
command prompt
type "tree" without quotes
drag your curser over it all and hit enter
paste into notepad
tree /? (for help on switches you may want to use) -
You can use a program like PrintFolderPro to do this, and it can also be done from a Command Prompt screen - I seem to recall a thread about this a few months ago, but I don't remember where it is. I use PrintFolderPro and save the headache.
There's a couple of other programs around that do essentially the same thing. Also, for whatever reason, Windows was never designed to do this simple task, hence, the aftermarket programs to give this functionality.
Free trial copy of PrintFolderPro here:
http://no-nonsense-software.com/printfolder/
Edit: Thanks, Stilt - I knew there was another way to do it, just didn't remember how...Ethernet (n): something used to catch the etherbunny -
There used to be a DOS command too where you could do a "DIR" and have it output to the printer:
dir c:\name\*.* >LPT1:
I think it was -
... or if all you want is filenames without the extra bits (directory, filesize etc) and write it to a text file, use ...
dir /b "yourpath" > "filelist.txt" -
Originally Posted by bunyip
@bunyip: I tried your command and it didn't quite work. Basically I'm having an issue with the yourpath part. the folder I want the list of is as follows in dos... E:\MP3\Music Vids
and I tried typing it as...
dir /b E:\MP3\Music Vids> filelist.txt
It responded with 2 lines that said... File Not Found
Did I type something wrong there? -
Hi dqtus,
When there is a space in a directory or filename in windows you need to enclose it in quotes, otherwise it will stop at the space and treat the rest as command-line parameters.
So you should type ..
dir /b "E:\MP3\Music Vids" > filelist.txt -
Wow you guys are so amazing to remember all these dos prompts. Thanks again ^_^
or you can used the truncated 8.3 directory name, i.e. mydocu~1 or progra~1
Originally Posted by dqtus
Notepad to spellcheck SRTs with underscore facility
By cal_tony in forum SubtitleReplies: 8Last Post: 2nd Nov 2011, 22:43 -
cannot copy files to computer or copy dvd
By moshik16 in forum Newbie / General discussionsReplies: 0Last Post: 14th Feb 2010, 16:09 -
NotePad and WordPad disappeared (WXP Home)
By walter4h in forum ComputerReplies: 2Last Post: 6th May 2008, 15:16 -
MP4[h264] Chapters with notepad?
By madmillington in forum DVD RippingReplies: 1Last Post: 9th Feb 2008, 23:05 -
What do I do with <filename>.avi.001 files?
By Hank Kinsley in forum Newbie / General discussionsReplies: 5Last Post: 26th Aug 2007, 05:25
