I have been having a problem backing up my copy of The Bourne Supremacy DVD using DVD Shrink. I use DVD Decryptor then DVD Shrink to back up the files, but whenever DVD Shrink gets to the 99% mark, an error message pops up and I have to close the application. I tried decrypting the DVD files twice there after and still have the same problem with DVD Shrink. Is there a known problem with The Bourne Surpemacy, or is my DVD Shrink just messing up? Anyone have any suggestions? I've never had any problems backing up DVD's with DVD Shrink, this is my first problem ever. Thanks in advance for any help or tips.
~ Kirk
You might want to reinstall DVD Decrypter and get the newest version. I had successfully backed up the Bourne Supremacy. You could try Smartripper that seems to work when the other programs don't.
Kevin -
its got nothing to do with dvddecrypter,he said he could rip it no problem,his problem lies with shrink,try updating dvd shrink,or use another version.
even try something like dvd2one. -
Someone else had this issue and the fix was to make the Unreferenced Material uncompressed or still image. It might just be a certain region release of the DVD I think.
If in doubt, Google it. -
Sorry,
I totally misread the thread...
I hate it when I do that.
Kevin -
Happens to the best of us....
Are the Jason Bourne books worth a read? I like the movies so far....
By yoda313 in forum Off topicReplies: 10Last Post: 11th Aug 2011, 17:25 -
Problem backing up Blu-Ray using BD Rebuilder with milOtis method
By TJMac44 in forum Blu-ray RippingReplies: 15Last Post: 7th Mar 2011, 14:43 -
Problem backing up my copy of transformers 2,i got it ripped but can't burn
By sscottsa in forum DVD RippingReplies: 1Last Post: 22nd Oct 2009, 18:18 -
burning problem with backing up my dvd's
By sscottsa315 in forum Authoring (DVD)Replies: 8Last Post: 5th Mar 2009, 20:36 -
Bourne Supremacy; Interactual Player software included and unable to backup
By videobruce in forum DVD RippingReplies: 9Last Post: 28th Dec 2007, 10:39
