Hi,
Anyone knows in what size my original Video must be to encode (S)VCD in real 16:9 quality and keeping AspectRatio, without TMPGenc adding borders to the video.
What size and wich settings should I set in TMPGenc for 16:9?
ex. I ripped a DVD and saved it directly to mJPEG AVI. This was saved in 16:9. After encoding in TMPGenc to SVCD I had a plain ordinary SVCD 4:3 (with borders created by TMPGenc).
Thanks.
When I use TMPGEnc to encode my 16:9 source to SVCD, I select the source as 4:3 NTSC. The result will be a horizontally squeezed SVCD. When you play it back on a 16:9 set, you now can use FULL mode to view it.
-derek
Here comes the real Skynet...
By ahhaa in forum ComputerReplies: 0Last Post: 19th Aug 2009, 09:57 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Tmpgenc Express rendering real video, result no sound
By pcb in forum Newbie / General discussionsReplies: 0Last Post: 31st May 2008, 14:17 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
what is upconversion real mean?
By Xnici in forum DVB / IPTVReplies: 13Last Post: 23rd Jul 2007, 12:36
