  1. I made a DVD backup the other day, and it did not work in my dvd player. I think I might have messed up and said the region was PAL instead of NTSC. So I was wondering is the any program or way to check if the dvd I made is PAL or NTSC? Thanks
  2. Ok I found out how to check the file. And it is in the wrong region. Is there any way i can convert the PAL dvd to NTSC?
