Alright, I have 27 .avi files and it equals to 2.37 GB each vid is about 20 mins long.. What are my options for making each of these dvd complient and burning to DVD .. how many dvd-rs do you think this will take? Thx -Adam
only_emo_kidGuest
Realistically I would say 7-8 titles per DVD(video:2000Kbps,audio:192kbps),so you are looking at 4 discs.
I would use TMPGEnc DVD Author,but you might have to convert the audio to WAV first: www.videohelp.com/forum/viewtopic.php?t=243709 -
only_emo_kidGuest
alright.. Thx
I hate having to put stuff like that on 4 cds.. it came on 5cdrs lmao, but Since the output for mpeg2 will be bigger and time wise.. Thx
I prefer not to hazard a guess without knowing the stats of your source files ie. 200okbps might be overkill or not sufficient, depending on the frame size and the bitrate these clips are encoded in. Do they all have the same specs ? If so, what are they ? (Post some screenshots from GSpot)
If in doubt, Google it. -
Based on the info you gave the avi's were probably encoded at just under 600 kbs including the audio. Unless the originals are from a very good source you may not like the results. I agree with MOVIEGEEK, it should take about 4 or 5 discs depending on the final framerate. Whatever mpeg encoder you decide on, test with ReWritable discs if you can.Originally Posted by only_emo_kid
only_emo_kidGuest
I'll get some screen shots sometime tongiht... i'm lazy right now and my g/f is here... but they aren't the best quality... they're old teenage mutant ninja turtle eps, and i have some space ghost and the tick
hmm
By sve in forum TestReplies: 19Last Post: 29th Feb 2012, 04:15 -
Set default MKV size in DVDfab for a 4.37GB DVD disc?
By iamkatpeeler in forum Authoring (Blu-ray)Replies: 7Last Post: 24th Apr 2011, 10:59 -
4.37gb mkv file to avchd
By PSS2 in forum Authoring (Blu-ray)Replies: 6Last Post: 12th May 2010, 14:12 -
Dvdshrink/DVD 5 4.35gb or 4.37gb ?
By cyflyer in forum DVD RippingReplies: 6Last Post: 7th Nov 2008, 02:40 -
when joining 2x700mb .avi files with ffmpegx the result is 1.37gb
By isaachunt in forum ffmpegX general discussionReplies: 2Last Post: 25th Jul 2007, 03:26
