hi,
whare is the right link for the real lib download. i cant find the file http://forms.helixcommunity.org/helixdnaclient/index.html?filename=DR5/client-1.1.5-De...clients.tar.gz on helix website. there a lot different downloads like:
all_clients-helix-20041208-macos-gcc3-pb.tar.gz
hxplay-1.1.0.603-linux-2.2-libc6-gcc32-powerpc.tar.bz2
i cant find the file which is shown in ffmpegx. what is the right one...
cheers tom
Results 1 to 15 of 15
The Helix site changed their files. I'm preparing a new release with the right links. In the meantime, download this file:
http://forms.helixcommunity.org/helix/builds/index.html?filename=20041208/all_clients-...gcc3-pb.tar.gz
Then after decompression, rename the folder as client-1.1.5-DevRel_macos-gcc3-pb_all_clients
i've got 0.0.9r now, and i am still having this problem with the reallibs--
the installer pretends to recognize the link i made to the folder
but if i click on "install binaries" again in ffmpegX then it still shows up as not having been installed.
i tried trashing and reinstalling ffmpegX several times and still the same problem. What am i doing wrong?
Download http://homepage.mac.com/major4/reallib.zip, unzip and put the folder in /Library/Application Support/ffmpegX
I will make reallibs an optional install in ffmpegX 0.0.9sn as the continuous change of builds from Helix make this process a little difficult.
i did that but still no go. The installer accepts the link as if it worked, but if i try to encode a real media file (which is unfortunately what i need to do and why i am suffering from all this trouble) it chimes very happily as if it worked, but gives me a 0 kb empty file. the encoding report reads as:
Encoding started on Mon Jan 10 20:27:51 CET 2005
[NULL @ 0x38430c]Unsupported video codec
Input #0, rm, from '/Users/liletbreddels/Desktop/new_europe.rm':
Duration: 00:12:45.3, start: 0.000000, bitrate: 998 kb/s
Stream #0.0: Data: 0x0000, 96 kb/s
Stream #0.1: Data: 0x0000, 403 kb/s
Stream #0.2: Data: 0x0000
Stream #0.3: Audio: 0x0000, 8 kb/s
Stream #0.4: Audio: 0x0000, 16 kb/s
Stream #0.5: Audio: 0x0000, 32 kb/s
Stream #0.6: Audio: 0x0000, 96 kb/s
Stream #0.7: Data: 0x30345652, 39 kb/s
Stream #0.8: Data: 0x30345652, 55 kb/s
Stream #0.9: Data: 0x30345652, 112 kb/s
Stream #0.10: Data: 0x30345652, 223 kb/s
Stream #0.11: Data: 0x30345652, 403 kb/s
Stream #0.12: Data: 0x30345652, 39 kb/s
Number of stream maps must match number of output streams
so obviously it hasn't done anything, and if i check the reallibs in the installer again, it shows up again in red as missing. i already tried deleting and reinstalling ffmpegX, but the problem persists. what's the next thing to try?
Real nOOb, VirtualDub-1.9.7
By LarryLaser in forum Newbie / General discussionsReplies: 1Last Post: 6th Nov 2009, 21:34 -
Here comes the real Skynet...
By ahhaa in forum ComputerReplies: 0Last Post: 19th Aug 2009, 10:57 -
Real Player Format
By Russo in forum Newbie / General discussionsReplies: 3Last Post: 1st Dec 2007, 00:00 -
Seagate being sued - is this for real?
By piano632 in forum ComputerReplies: 7Last Post: 22nd Oct 2007, 14:29 -
what is upconversion real mean?
By Xnici in forum DVB / IPTVReplies: 13Last Post: 23rd Jul 2007, 13:36
