  1. i have a m2v file and a wav file i want to multiplex in tmpgenc, but i get this error for the wav "multiplexing linear pcm stream to system stream is not supported". converting to mp3 didn't work either. what format of wav should i convert it to?
  2. Is this for a DVD application?
    Have you tried (48 khz) MPEG audio?
  3. Member Soopafresh's Avatar
    Jan 2004
    Convert the Wav To MP2 or AC3 with ffmpegGUI
    Make sure you encode at 48Khz and at least 224Kbs - use 384Kbs if you have the space.
