i have an xvid avi file and when i go to convert it to mpeg-2 in tmpgenc it encodes for too long. in other words it keeps encoding after the length of the movie is done...it says its more frames then it should be (it should be around 37596 but it says its 83696 frames, thats more than double!!)...it stays on the part where the last frame should be and keeps on encoding......anyone know why this is happening?
Corrupted or missing frames, bad GOP header, VBR MP3 audio, improper changing of framerate, or just an entirely corrupted file to begin with...
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Run it through DivFix http://divfix.maxeline.com/divfix.html and try the fixed copy. You can also open the Avi file in VirtualDub and choose "Scan Video Stream for Errors" to verify it.
Tmpgenc doesn't like variable bitrate audio. Use VirtualDub or something else to save the audio as a WAV file. Then use that WAV file in Tmpgenc.
ways to determine the bitrate of your dvd to xvid or h264 encodes
By codemaster in forum DVD RippingReplies: 2Last Post: 21st Sep 2011, 22:25 -
Cannot compare lossless with MPEG-2 encodes: Frames aren't lining up!
By Mini-Me in forum Video ConversionReplies: 15Last Post: 5th Dec 2010, 02:08 -
Speed up xvid encodes?
By rhijaen in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2010, 01:48 -
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 01:46 -
Question About Widescreen, I Think, Two Xvid Encodes
By hech54 in forum DVD RippingReplies: 5Last Post: 16th Sep 2008, 16:54
