  1. Can you detail the procedures?
    Apr 2004
    Miskatonic U
    I am using Nero Ultra 6.3.1.20, with an NEC2500A single layer burner. All I did was apply the firmware update to make it dual-layer, and Nero recognises it as such. No change to Nero was required.
    I'm not sure I understand your question - perhaps you could detail the problem you have ?
    Read my blog here.
  3. Check in NERO that your burner is capable of recording 'DVD+R9'.
    Go into 'Recorder' -> 'Choose Recorder' and then select your recorder and it (DVD+R9) should show up in the 'Disc types'.
    If you don't see it, you either have a version of Nero which is too old and it doesn't recognise your drive, or the firmware in your DVD burner is too old.
    Or you don't have a DL compatible burner.
    Good luck.
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    The latest version of tmpgenc dvd author supports dl burning.
    Also for backups you can use dvd decrypter iso read, iso write.
    Just some alternatives for you
    Kevin
  5. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Originally Posted by yoda313
    Hello,
    Kevin
    He's trying to get Nero to do it. Nero 6 supports DL burning and if it doesn't recognize the burner as DL I'd say you have firmware or other hardware issues with the burner. If it's installed correctly, and the drive is up to date, Nero should see it when you use "Choose Recorder".
