I authored a DVD using TMPGenc DVD Author..
Problem is DVD will play on my computer, but when I use it in my Toshiba set top DVD player it will play for 3 secs and freeze? Any suggestions on how to fix this problem?
Results 1 to 9 of 9
Hello M., The problem may be a variety of things....! Take the DVD to your local DVD player store & try playing it on a variety of machines. If most of the players play the DVD, then the problem is more than likely your DVD player - it may be too old. If the same problem happens with the other DVD players, then the problem lies in your mpeg-2 files or somewhere in your authoring process.
Good Luck...
Doc_BReach for the Starz -
Sounds like bad media, or the non-compliant TDA burning engine (known to do this!)
Try output as a video_ts folder in tmpgenc dvd author and burn with another burn tool, https://www.videohelp.com/guides.php?howtoselect=3;25#3;25
If it doesn't help it is probably baaaaaad media. -
You been hanging out with Cap again?Originally Posted by Baldrick
Ok I tried using divx to dvd software by vso and again used Nero to burn the Video_TS folder to a DVD-RW (Verbatim) I changed the encoding software and the media and got the same results. The DVD-RW will play on the computer. Looks like it's my DVD player...But I have authored other DVD's with the same media and it plays.
Could there be a problem with my Toshiba SD 430 V? -
Hi,
I have the same pb as well, so I do all the authroing with Tmpg DVD Authoring, then burn with CloneDVD2, and it works nicely. Good luck.
Problem Playing Authored/Burned Dvd on DVD Player
By djgazzabhoy in forum Video ConversionReplies: 10Last Post: 24th Nov 2011, 15:15 -
fast forwarding authored DVD causes sync problem
By snafubaby in forum Authoring (DVD)Replies: 3Last Post: 15th Feb 2010, 01:10 -
Samsung BP3600 problem playing Nero authored DVD's
By stonejg in forum DVD & Blu-ray PlayersReplies: 6Last Post: 10th Jan 2010, 13:56 -
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 20:01 -
Authored DVD sticks
By lbigfoot in forum Authoring (DVD)Replies: 5Last Post: 11th Jan 2008, 13:41
