I've tried everything I can think of to get this audio file to convert to DVD format.
It's an mp3 track. I've transcoded a wav with Cool Edit Pro (to use to create mps or ac3) and wav, ac3, mp2 with Besweet GUI. All processes work fine according to the logs, but usually play speeded up and distorted. If they do play on a player, the sync might be off.
I finally got a mp2 that worked in the DVDAuthor during the clip edit, but I get an "illegal audio format" message about thirty seconds into the authoring.
The original file is mono, by the way, if that matters. I was careful to make sure the bitrate was 224 and the rate at 48000 hz. Any ideas what is going wrong?
MP3 is not DVD compliant.
MP2, WAV/IAFF (PCM), AC3, DTSWant my help? Ask here! (not via PM!)
Lord Smurf - the original file is MP3 - I have transcoded it to all of the correct dvd formats, but no go.
Yes, Soopahfresh, this is for DVD and I will try the FFMPEGGUI transcoder - I was wondering about it when I saw it in the tools. I mux with TMPEG DVD Author, usually.
Thanks. -
I suspect it might matter. I don't use your software but have encountered errors earlier authoring VCDs and attempting to use a mono stream. The simplest way I can think of to test that theory is by turning your mono stream WAV into a stereo stream WAV (same content, both tracks) and then cranking out an MP2 from it, trying it again. Good luck.Originally Posted by alvin grung
MPEG Streamclip: "Audio Decoding Error"
By addresstom in forum AudioReplies: 3Last Post: 30th Aug 2011, 11:12 -
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2010, 00:05 -
VirtualDub "format convert" audio filter - how do I use it?
By Jedi787Plus in forum AudioReplies: 0Last Post: 12th Sep 2009, 16:35 -
Need some help with "dubbing"/"muxing" video with audio
By FSSSWE in forum Newbie / General discussionsReplies: 9Last Post: 21st Jun 2008, 19:49 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
