Results 1 to 10 of 10
    jupiter
    well im haveing trouble where can i get the intervideo audio decoder and register it with Vob2Audio????....i know i get it with WinDVD but i im useing with PowerDVD and i want to keep PowerDVD...can you guys give me a link to a site that i can get the decoder ???????...please help me!!!!!!!
  2. try to reinstall the vob2audio and that should do the trick..i had the same problem and i just reinstalled it and it work fine again
    Feb 2001
    Berlin, Germany
    Does vob2audio use the intervideo audio decoder?
    Reinstalling vob2audio might not help, because the intervideo audio decoder is not part of the vob2audio package, only the Ligos splitter.
    pinoy2201, did you install WinDVD?
  4. Nope i only have PowerDVD curently installed on my computer
    trust me it is included with the package
  5. and oh yea Vob2Audio uses intervideo audio decoder
    Feb 2001
    Berlin, Germany
    That is strange, iviaudio.ax is the intervideo audio decoder. "My" vob2audio came with mpeg2parser.ax and lmpgspl.ax only, both are ligos tools, both are part of the streams package. I had problems with vob2audio sometimes until I updated the Ligos splitter. Now it workes fine, but I would like to know, whether the intervideo decoder is needed, I have installed windvd btw.
    Feb 2001
    Berlin, Germany
    Maybe vob2audio install it and put it directly in the system resp. system32 directory. Pinoy2201, please have a look at that dir and tell me which version of iviaudio.ax do you find. It do not let me sleep.
  8. yea vob2audio uses WinDVDs audio deacoder..and my iviaudio version is 2.0...i guess that if vob2audio detects you dont have WinDVD it installs the intervideo audio decoder...and my WinDVD hasnt touched my computer yet
    Feb 2001
    Berlin, Germany
    Now I see, thanks a lot.
  10. yeah...no problem
