Hi, I recently bought a Pioneer DVR108 DVD writer and was happily using it for about 1 week with the "Cyberlink PowerDVD" program until it started telling me that it was locked to region 1 only. I had played region 2 DVDs on it before and had no problems. I have since found out that it only gives you 5 chances to set the region! I bought this thinking it was multiregion! I have also heard that it is possible to fix this problem, tho on searching the web and this forum I have found no solutions. I also tried a firmwear download which doesn't seem to have done anything.
Can anyone shed some light on this subject for me? Or am I going to have to buy a new one? PLease Help! PLease!!!!!!![]()
You only get 5 goes ... by default.
http://forum.rpc1.org/dl_all.php will have a firmware that can make it region-free, or there is softwares under the Region Free banner in the tools section that can do same.If in doubt, Google it. -
Thanks for your help. I managed to apply the firmware and the drive itself is now multi-region though Power dvd still only allows 5 region changes before locking to region 2. Is it possible to patch power dvd to make it region free? Any suggestions about how to solve this problem are most welcome. If there are any other players that are region free please let me know. Thanks
try installing DVD REGION KILLER. it will fool the operating system so you won't have that annoying 5 changes thingy.
Soniq QMD80B Portable region coding firmware update
By twiztid in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Aug 2010, 03:44 -
Region coding on burned disks.
By sambat in forum Authoring (DVD)Replies: 6Last Post: 14th May 2010, 16:59 -
BluRay Region Coding Announced - Japan & US Same Region
By GullyFoyle in forum Latest Video NewsReplies: 57Last Post: 18th Dec 2008, 15:55 -
DVD Region Coding
By jasej in forum Authoring (DVD)Replies: 5Last Post: 27th Jul 2007, 07:59 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 21:35
