Results 1 to 28 of 28
  1. I have a VOB file that is 4.05 GB. how do i burn this to a dvd? i can't use nero because it says that it is bigger than 2 GB and use some UDS file system to do somthing... i can't get it up rite now, cuase its not responding. And i don't know how to use Roxio, its just too confusing. how do i burn this to a dvd?
    -thanks
    You must author it to a real dvd(ifo,vob,bup files), import it in tmpgenc dvd author or some other dvd authoring tooooooool(check our tooooools list here to the left)
  3. ok, i got tmpgenc dvd author. but i still can't convert it, it gives me the following error:
    the video GOP is too long.
    if you are using the xdvd format, you can ignore this message.
    then it gives me the following options, details, ignore, and cancel.
    when i click ignore, it tells me that ignoring these messages will give you an out of standard dvd.
    wht do i do?
    -thanks
  4. help anyone? or maybe should i try another section?
  5. Originally Posted by undead.ltd
    wht do i do?
    I click Ignore and continue with the authoring. DVD almost always turns out just fine.
    That's my opinion, and if you don't like it, I'll change it.
  6. Member Soopafresh's Avatar
    Jan 2004
    Get a copy of VOBEDIT http://www.ifoedit.com/ and open up your VOB file with it. Click the DEMUX button and check the "Demux All Video Streams" AND "Demux All Audio Streams". This will give you a .M2V video and an .AC3 or .MP2 audio file.
    You'll can then ReMux the video and audio file with ReJig or MuxMan, which will create the .IFO .BUP and .VOB files you need. No menus or fancy stuff, just your video.
  7. i used xilisoft video converter to convert the file into vob. the size of the soruce file is 720x400, but i can't find that size in the right hand column under video size. i change it to pal, and it shows me 720x576. i cannot change that value. wht do i do? here is where the guide is:
    http://www.dvd-guides.com/content/view/73/59/
    -thanks
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    720 X 400 is not DVD-compliant - See What is DVD (top left) for what is.
    I think Soopafresh has it down, but I don't know whether demux/remux will fix the GOP error. You'll more than likely get an "invalid resolution" error in TDA, so you might have to re-encode to DVD-compliant specs.
    If in doubt, Google it.
  9. how do i re-encode to dvd-compliant specs?
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Welcome to Videohelp.com. To your left, you will see a heading that says "How To". Under that, there is a section called "Convert". In here you will find a specific section of guides that deal with converting to DVD-compliant MPEG-2 files. For your convenience, use this link to go straight to the section you require. Pick a guide, and follow it. If you have any hesistations, post your questions back here. We hope you enjoy your day and thankyou for visiting videohelp.com.
  11. lol, so dvd is mpeg 2? didn't know that, thannks
  12. ok, im trying to encode thru tmpgenc plus 2.5. i don't have an audio file tho. so i try the ac3 to wav conversion, but i can't do it. i have virtual dub, and when i say save wav, it tells me 'no audio decompressor could be found to decompress the audio format'. so i go bak and install the Ac3 acm decompressor, and extract it to the folder, but still i get the same error. under file info in virtual dub, it tells me that the channels are 6(stereo), there is no option like this in the guide. it tells me either 2 or 5(sterio). but as 5 is stereo, so i thought it would work. so any suggestions/ tips?
    -thanks
  13. sweet it worked!! thanks guys!! now imma convert! hope that works!
    wht should my aspect ratio be? 4:3 or 16:9. the source is a dvd rip, wide screen, so is that 16:9?
    -thanks
  14. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If it's widescreen, then it's more than likely 16:9.
  15. ok, i was converting on tmpgenc plus, and i ran out of disk space. its stuk at 89. is there anyways of restarting it?
    -thanks
  16. anyone? i ran out of disk space, so it stopped converting. how do i restart it? i don't wanna wait another day or two for it to convert when im at 89%.
  17. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Yet you waited another day to bump this thread ....
    There's no way to restart it at 89% - you must do the whole thing over again from the start.
  18. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    I would suggest clearing some disk space before you restart it!
  19. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by tekkieman
    I would suggest clearing some disk space before you restat it!
    I should have mentioned that toooooooo ...
  20. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    We can't all always be perfect.
  21. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
  22. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    At least fix my typo in the quote! I'd hate to look foolish!
  23. Member
    Apr 2003
    Largo, FL
    Sometimes when TMPGEnc Plus gets hung up the file it created is still usable to where it stopped. Just try to import the 89% file into TDA and see if it plays. If it does, just got to the same point in Plus and set that as the start point, then convert the last 11%.
    If that doesn't work I guess you'll have to do the whole thing over.
  24. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Well then, you'd better fix your quote of my quote of your quote then
    Hang on ...
    Here:
    https://www.videohelp.com/forum/viewtopic.php?p=1146003#1146003
  25. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Yup, that's the shorthand name.
  26. ok, i finally got home!! and after checking the print of the converted movies, i can tell they are pretty bad! they are worst than the original print! it says dvd rip, xvid on the file name, and the print is great! but after converting, it becomes all weird. the screen is wider than the original print, or bigger i guess, in size, and its all hazy. i think i got all the setings rite when i was converting. you guys have any suggestions?
