Hi,
when I burn couple VCD onto DVD, I usually would need to use TMPGEnc to merge the MPEGs together first, then reencode again to change the dimension or so...
This time I have a MPEG ... with a incomplete frame in the middle, let say on the 40 min spots.
Because of the bad frame in the middle, TMPEGENC stops right at the
bad frame, 40 mins spot
How can I fix it?
I tried to take the bad spot away by using TMPGEnc to copy from beginning to 39 min, and another file from 41 min to the end... however, that doesn't
work either.. because TMPGEnc will stop at the bad spot (the 40 min spot) and the 2nd file (the one from 41min to end) will not be made at all..
is there anyway to fix that incomplete frame? either fill it with all black.. or at least, is there any way for me to CUT that frame out?
thanks
thanks.. it seems working good... it would be better if there are crack for it..
btw, is there any freeware with the same features?
thanks -
Originally Posted by softech
Don't tell anyone about this, but if you go to this page:
http://www.drdsystems.com/VideoReDo/purchase.htm
and enter all the info it asks for, they'll send you a secret activation codethat will let you use the program for as long as you want!
ps Dont tell anyone about this.You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
Cut AVCHD not aligned at the frame boundary
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 3rd Aug 2010, 21:54 -
How to cut xvid avi by a non-key frame
By Kirill in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2010, 06:52 -
How can I cut out an image from a mpg file? Just one frame
By szalaikornel in forum Video ConversionReplies: 4Last Post: 28th Jan 2009, 10:59 -
Videoredo Cut a Single Frame ?
By acestu in forum EditingReplies: 4Last Post: 3rd Sep 2008, 09:06 -
What Video editor's can cut frame by frame?
By VEBouto in forum Newbie / General discussionsReplies: 19Last Post: 28th Oct 2007, 01:31
