  1. Member nick101181's Avatar
    Sep 2000
    Toronto, Canuck Country
    I followed the guide over at doom9 for using ifoedit to do this. I followed all the instructions to a "T". My problem is when I go to burn the two dvd's the first one fails in recordnow max, so I tried nero. In nero it says file allocation wrong needs video_01_7.vob . I made sure to correct the vts sectors on all the ifo files on both discs. Does anyone know why this is not working properly? this is the guide I used
    http://www.doom9.org/index.html?/mpg/ifoedit-2dvdrs.htm
    I didn't make the dvd's into iso's I'm trying to burn them using recordnow max. thanks
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    One of the IFOs is still pointing to VTS_01_7.VOB for some reason, even though it shouldn't be. Would you consider using DVDShrink in reauthor mode, with compression set at no compression, and use it's start/end feature to do the splitting instead ?
    If in doubt, Google it.
