I am using a licensed EO Video v1.36 to convert RM to SVCD.
After the conversion to MPEG2 is complete, I play the output file and the picture freezes after a few minutes.
Is there a workaround/fix/remedy for this? What is the cause?
Thanks.
Encode the audio and the video separately and then mux. Don't know why-but it helps!!
Thank you for the response.
I am unable to do a video-only or audio-only conversion. Must be missing something obvious. Output format used is: MPEG, Compression: SVCD (want a SVCD-format file...MPEG2, 480x480). Is an intermediate format required to split the audio/video into separate files? I tried AVI but still don't see it.
Thanks.
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
svcd on windows 7 : Vob Size problem?
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Jan 2010, 14:58 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 17:38 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
