    Mar 2002
    I have been using svcd2dvd for ages now and never had a problem, have just changed my standalone to a LiteOn 5005 and now the multis wont work.
    I made them with vrersion 1.5
    I dont get any menu and when i hit play the 1st film plays but i can never get to the other films on disc.
    When i try on one of my old dvd standalone they work fine.
    I havenbt wanted to use the Beta 2 much due to ther incompatibilities it has been having.
    BTW i have tried the Beta 2 version and the menu seems to wiork.
    Any ideas?
    Mar 2002
    Any ideas or do i just wait until Version is finally released?
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Sounds like your LiteOn doesn't like the menu's from v1.5. Can you not navigate to the other Titles with your remote?
    If v2 works with the LiteOn - go with that. The menus and the authored DVD are more compatible with more players and its a lot quicker at processing.
