Im using gordion knot to convert ntsc dvd (29.970) to xvid
i have already converted about 10 similar dvds with the same software
they were fine
this dvd seems to be fine too until it is ripped
this dvd shows a blocky picture for the last half of the movie
the last time seemed to be only for the last third of the movie
and the previous dvd i also came across this problem
after several attempts i decided to use divx
it worked so i assume this problem is connected with xvid or xvid settings
i used codec sniper but found no broken codecs so i removed nothing
i unistalled xvid and reinstalled it (XviD-1.0.2-29082004)
ive used this guide to the letter - GKnot 0.32.0 ILLUSTRATED GUIDE v.8 by dap & js
at least i think i did
i think the problem here is probably very simple but i cant figure it out
and basically i need to let my pc run overnight to see if the rip was working or not so it takes a long time to check it
i know i can use divx but id prefer to use xvid
so if anyone has come across this problem
or can find a thread that you think might help me (i couldnt find one) id really appreciate it
Can you rip the dvd to your drive ok?
Only way I can think to reproduce the problem is using zones to set the jast part of the movie to say a high fixed quant. Think GKNot has a credits option. You aren't incorrectly setting it to during the movie?
Originally Posted by Hardcoreruss
Originally Posted by celtic_druid
thanks to both of you for the reply
Xvid creates blocky artifacts! Help!
By david.dgc in forum Newbie / General discussionsReplies: 35Last Post: 18th Apr 2012, 12:27 -
My video keeps getting cut in half during conversion
By FatalX in forum Video ConversionReplies: 4Last Post: 8th Nov 2009, 09:57 -
PAL to NTSC renders OK on top of picture, flickers on bottom half
By Exiled_Brit in forum Video ConversionReplies: 6Last Post: 21st Sep 2008, 14:31 -
Blocky conversion DV-->Mpeg2 @ 9000Kbps using TMPGEnc 4.0
By kamaleon in forum Video ConversionReplies: 34Last Post: 15th Jul 2007, 17:25 -
Half a conversion
By error in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 30th May 2007, 17:23
