Hi,
Could anyone tell me how with IFOedit I can tell a dvd to return to the main menu when the movie ends.
You can do that with PgcEdit (which makes it much easier than IfoEdit to modify the DVD program flow). And it's free too!
Just open your DVD in PgcEdit. Find where your movie is (should be easy, there's even a preview in PgcEdit) and go to the post-command area.
There you'll want to insert a command at the top of the post-command area
[30 08 00 00 01 83 00 00] 1 (CallSS) Call the VTSM Root menu of the current VTS, resume cell 1
since the root menu will probably be in the same VTS. To do that simply click on the "********** Post commands" line and click on "Add After".
Double click on the NOP command and change it to the command above.
This should do the trick.
JeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob. -
While we're on this subject how about a method for patching a DVD to keep replaying the main movie over and over when you hit the end. Will be great for amusing the kids.
That's a cinch with PgcEdit:Originally Posted by pjcrown
Add a LinkTopPG as the first post-command of the movie PGC and you're done: when the dvd finishes movie playback, it executes the first post-command and automatically goes straight to the first program of the PGC...
I need IFOedit for Mac
By bryceguy in forum MacReplies: 7Last Post: 14th Dec 2011, 12:45 -
Changing a 4:3 menu to 16:9 using ifoedit
By NBninja8 in forum Authoring (DVD)Replies: 4Last Post: 20th Jan 2009, 21:11 -
ifoedit question
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 04:10 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 01:42 -
adding CC with ifoedit
By loster in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 20:15
