Can anyone tell me why I am getting a popup that says "The Broadcast signal is protected from being recorded and can only be viewed. Recording will be terminated." when I am capturing from my All-In-Wonder TV? I usually capture (record) a few tv programs to watch later. After a little bit of capturing, I get the pop-up. It doesnt seem to be consistent on how long it takes before it occurs. I am capturing from a satellite composite connection. It does not stop my sceduled program from recording, but after the scheduled program is over, while it stops recording, it doesnt go away so therefore any later scheduled programs do not start until I click "OK" to close the error. I am not sure why it started doing this. I do not know if this error is coming from the ATI TV program, or where. Any thoughts?? John
Not an error:
https://www.videohelp.com/forum/viewtopic.php?t=246129Want my help? Ask here! (not via PM!)
It's coming from your card due to it detecting macrovision protection or at least thinking it detects it. It's an annoyance at best, as you can still record!
"Rarely is the question asked: Is our children learning?"
George W Bush - Moron -
It's not the software.
It's drivers and/or hardware, and pretty much every single capture card, DVD recorder and VCR comes with it these days.
See the link in my above post.Want my help? Ask here! (not via PM!)
Yeah Smurf, some Nvidia cards have the same problems due to WDM drivers. Damn thing won't let you capture even when the video is not protected in any way, and it doesn't matter which software you use.
Guys thanks for your replies!! It is hard for me to say what is causing this since I have upgraded Drivers, ATI sw version, etc and this started somwhere in the middle of this. Lordsmurf that was a pretty good explanation in your link. But it sounds gloomy. The only way to get aroound this "false protected error" is to by hardware to do so? The popup itself is not a problem, but I cant capture 2 or more programs without manual intervention to click "ok". There is no way to avoid that without spending money for a false copy protected signal? Thanks again for responses!!
Originally Posted by johncat
Converting PAL to NTSC error Attempted to read or write protected memory.
By VHSonDVD in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 26th Oct 2009, 07:15 -
Cannot Record Protected Movie error using Samsung DVD-HR734 recorder
By noreberto in forum DVD & Blu-ray RecordersReplies: 6Last Post: 7th Nov 2008, 15:51 -
Broadcast signals starting to be copy protected?
By duffy76 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Jul 2008, 12:23 -
TS for broadcast
By elgemo in forum DVB / IPTVReplies: 0Last Post: 16th Jun 2007, 12:52
