Hi,
When I'm converting my DV 2.0 avi's to DVD mpeg with TMPGEnc or any other conversion tool the mpeg ends up alot lighter than the original.
If I play the video with the DV as source(trough my computer or a camrecorder) it looks great, but burnt down to a dvd+r it looks terrible.
I could probably fix it with the simple color conversion tool or something, but why does this happen, and is there any simple way way to avoid it?
Hi julen001,
Welcome to the forums
Check out this guide:
https://www.videohelp.com/guides.php?guideid=303#303
...on TMPGEnc settings - particularly the bit about "Output basic YCbCr" under the "Quantize matrix" section.
That might be of use / interest...
Be sure to vote for the guide if you use it.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Hm thank's, but i didn't find anything that could help me out.
That setting was already set to the right option, and changing it just gave me an even lighter picture. -
Be sure to compare your DV source and DVD-r on a TV and not the computer. Computer monitors have expanded color levels.
Computer = 0-255
TV = 16-235
Some programs automatically compensate for that when viewing, but to be sure test on your TV. -
Well yeah, I've watched it on the TV with my computer as source via the tv-out and on a TV trough my camrecorder. It's definitely lighter after the conversion to mpeg, and no matter wath the tools I use, it seems.
I would test on a stand alone DVD player.
Computer might be compressing the 0-255 down to 16-235 before it sends it out through the tv-out.
That means your 16-235 DVD-R is being compressed down to 32-205 through the tv-out.
Again this is all dependent on programs used and how.
This is just a guess though, sorry.
My VHS captures through my DVcam passthrough, converted with TMPGenc, with "Output basic YCbCr" enabled, look exactly like the source.
I test on TV and switch between DVD player and VCR and look for differences, including black levels.
I just tell you this because it is possible to do what you want. There is just something unknown messing it up, it seems, in your process. -
Yeah thank's for the help, but i've been testing trough the s-video out on my camera as well, and the dvd's i burn gets insanely light too!
Question on auto exposure when room is darker but windows are lighter.
By etbrown4 in forum Newbie / General discussionsReplies: 9Last Post: 26th Nov 2011, 19:13 -
DVD FLICK- ending cut off
By sheftic in forum Newbie / General discussionsReplies: 1Last Post: 8th Sep 2009, 01:29 -
i need alot of help converting .avi to dvd?
By just in forum Newbie / General discussionsReplies: 17Last Post: 21st Oct 2008, 14:51 -
i need alot of help with my volume on my dvd movie
By KITCAT12 in forum AudioReplies: 9Last Post: 28th Aug 2007, 21:06 -
Why is my HCenc resulting lighter/brighter AVI video?
By oavs in forum Video ConversionReplies: 16Last Post: 15th Jul 2007, 07:23
