I hope I am in the correct forum area. I am wondering if there a software which I can use to compress DVD files and then "expand" (for want of a better word) them later for burning to a DVD disc without loss of quality. I am trying to store as much DVD movies as I can on an external HDD.
Thanks for any answers.
If you do not learn from someone's knowledge and experience, then you are doing it the hard way
No. They are already compressed.
DVD video uses Mpeg2 compression. There are other compression types which can reduce the size while keeping an approximate quality level. Divx and Xvid spring to mind, they can achieve sizes 1/2 to 2/3 smaller than Mpeg2 with similar quality. However, it isn't possible (or practical) to convert twice (dvd>divx>dvd) without some quality loss. It would also involve some skill and quite a lot of computer time. However, if you just want to view the files on your PC, or if you have a Divx capable DVD player then converting to Divx might be a practical option.
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
