Ok, I converted a Real Media video to .avi format, and then converted that to a .mpg VCD file with TMPGEnc. There was a problem with the sound and the video is sorta blocky, so I want to try and re-convert the .mpg again, this time using the "sharpening filter" and using a .wav file for the sound...but I keep getting this "floating decimal" error. I looked around on the board, and people are saying that this means that there are some bad frames in the movie, but I disagree...I tried opening the original .avi file that I first converted, and it shows the same error. Why is it saying that there are bad frames in the video, when I was able to open it yesterday? How do I fix this?
Oh i forgot one thing...I can edit the exact same files on my other computer using the same program, so I know it can't be the files (the reason I need to edit on this computer is because this one has the cd burner...and it is much easier to edit the files and not have to transfer them from one comptuer to another).
Aegisub wont play mpg, converting using divxland causes problems
By denadel in forum SubtitleReplies: 2Last Post: 2nd Oct 2011, 05:36 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 22:18 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
