If anybody could help me...I click on svcd2dvd to start and it looks like its going to load, then nothing happens.....Its been working fine but now it doesnt...I tried reinstalling it but still the same thing...if you could help let me know..thanks keith
Results 1 to 9 of 9
Does your v1.5 behave the same way?
No...I can load 1.5 fine...v2 beta 6 just started doing this...Im trying everthing....I know if i uninstall it...then install it and start it.....It asks me for the registration #...Then I get the registration # from you and put it in..it registers and asks me if i wanna start program...and I do...It works then..but soon as I close it, it wont open again....I dont know.....Keith
ok. Can you drop me an email & we'll try to get to the bottom of it.
Hey Chris....I was at work...I just tried your new version beta 7 and registered it and i still cant load..Now I got this.......
Type: System.NullReferenceException
Source: Interop.CodeLock
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at CodeLock._Secure.Authenticate(String pass)
at AxCodeLock.AxSecure.Authenticate(String pass)
at x3284ccece41ee22b.x210ff09a2516b1a7.x41f470203acc6 a6e()
at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.ThreadContext.RunMessageLoopI nner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.ThreadContext.RunMessageLoop( Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322 395(String[] xce8d8c7e3c2c2426)
Not sure what happend...Let me know...if you want to email me..Its Jusplayn76@yahoo.com Thanks Keith -
I have made a small installation fix to Beta 7 - can you retry and let me know?
Hey Chris...I just downloaded the beta7 with the litte fix you said....Now I cant even install it.... It says " theres a problem with this Windows Installer Package . A program run as part as the setup did not finish as expected. Contact your support personnal or package vendor" Keith
What is your OS and service pack?
Hey chris.....I have windows xp and sp2....I will be back inawhile....Im going to work...Sucks
Talk 2 you in awhile.........Keith
VDub wont load *.VCF files in command line mode.
By zzyzx2 in forum Video ConversionReplies: 11Last Post: 15th Sep 2011, 06:48 -
virtual dub wont load the full vob
By tvlreject in forum EditingReplies: 19Last Post: 28th Mar 2008, 20:13 -
HDTV2DVD - .TS wont load
By NotSoEasy in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 15th Mar 2008, 19:09 -
dvr-ms at 59.94fps wont load
By dalego in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 7th Oct 2007, 17:38 -
xvid wont load in program
By dvdhouse111 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 6th Jul 2007, 04:26
