I am very new to all this. I Used my Canon Digital ZR80 to record some family video in 16:9 format. Then I used my Philips DVDR80 DVD recorder to record the images from the camcorder. Then, fool that I am, I recorded over teh digital tape. Then, I discovered that the Philips DVD recorder had not recorded the images in wide screen format. The video is squeezed into 4:3 format. Does anyone know a way or program or service that I can use to rescue and "unsqueeze" the video? Thank you.
Copy the files to your hard drive. Use Ifo edit and change the DAR to 16:9. Burn a new disk. Of course you need a PC DVD burner for this.
If you play back the Philips reorde disk on a standalone DVD player. Set up the player to tell it to play back at 16:9 and chances are it will look ok. -
You could also get some software that supports 16:9 such as Ulead Video Studio 8 (about the cheapest decent all-in-one) to use to edit and reauthor the disc with transitions, titles, chapters....etc.
Is it possible to re-edit a non-anamorphic dvd to anamorphic?
By Beautiful Alone in forum DVD RippingReplies: 45Last Post: 22nd Sep 2011, 10:00 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 16:46 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 21:03 -
anamorphic 16:9 DV treated as 4:3 DV !?
By arminio in forum Video ConversionReplies: 4Last Post: 12th Mar 2008, 12:03 -
anamorphic or not anamorphic
By cd090580 in forum Video ConversionReplies: 3Last Post: 23rd Jun 2007, 13:48
