Ok sorry the title isn't very descriptive because it would be too long then.
I have a SVCD broken up into 2 parts and are in .Bin/.Cue files. I copied the mpeg file to the hard drive and tried using TempENC Plus mpg tools to Simple Multiplex so I could put both parts onto a DVD-R, but the audio is out of sync afterafter doing this.
Anyway around this?
TMPGEnc seems to have problems with some MPGs that it did not create. I'm not sure what you are authoring with but if you use TMPGEnc DVD Author and import both files as a single track it will combine them without synce issues.
It might also be that there is something wrong with the files themselves that will cause the sync problems, so this advice may or may not solve your problem."Rarely is the question asked: Is our children learning?"
George W Bush - Moron -
I'm using Ulead MovieFactory 3.5 Suite, if I put it in there should it work fine if there is no problems with videos? Should I try it on a DVD-RW first?
Yep. Extract the video out of the bin/cue files (instructions in this sticky, although it sounds like you already haveOriginally Posted by Matt D
) and then use your favorite authoring software to add the two MPEGs into the one track. Your authoring software will join them automatically for you. If there's still synch issues then it's the files themselves, not the programs you are using.
As for testing, you should be able to tell your authoring software to output to your hard drive. do this and test the synch when playing off your hard drive. Optionally burn to a RW and try that on your standalone player also.If in doubt, Google it.
Video/sound out of sync and lagging on pc
By keaze in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2012, 23:09 -
Sound out of sync in ulead video studio..
By iames85 in forum AudioReplies: 5Last Post: 24th Apr 2011, 05:10 -
DVD Video/Sound out of sync!
By bprobinson in forum Authoring (DVD)Replies: 0Last Post: 23rd Feb 2010, 16:51 -
DIVX sound and video not in sync
By DarkPhoenix77 in forum MacReplies: 2Last Post: 27th Feb 2009, 12:48 -
Video and Sound are out of sync help!
By Rhoads in forum Authoring (DVD)Replies: 1Last Post: 14th May 2007, 21:11
