I am fairly new to this, but I had successfully burned a DVD a couple of months ago, and just this week I started out transferring home movies (8mm) to DVD. I am using the Nero Software Suite for all of this.
I got my first DVD set and burned, only to find out that the audio, which is plenty loud on the source AVI, is virtually non-existant on the DVD. If I crank the volume on the TV (or computer) I can barely hear it. So I burned it again, this time with the volume up to 167% but the result was the same.
The only thing I did differently from the successful burn earlier was that I didn't convert the AVI to MPEG2 before burning, but rather let Nero do it all at once.
If anyone has any idea what might be going on or how I can fix it I'd appreciate it.
Thanks in advance.
Dwayne
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
audio problems when burning a DVD
By cosypete in forum Authoring (DVD)Replies: 3Last Post: 9th May 2010, 19:23 -
Dl burning problems
By calanda in forum DVD RippingReplies: 13Last Post: 14th Apr 2010, 00:25 -
TYG02 burning problems.
By videobread in forum MediaReplies: 2Last Post: 11th Oct 2009, 13:51 -
Taking Audio from movie file, then burning audio to cd-r
By Justnmnmn in forum AudioReplies: 5Last Post: 22nd May 2009, 18:44
