I download full (legal) CDs all the time, Linux distros for instance. Not to mention that I'm very impatient when it comes to streaming media.![]()
Results 31 to 37 of 37
Nothing can stop me now, 'cause I don't care anymore.
I got a new NIC installed for her and set it up through that but her download speed is still maxing around 300kbps and upload at about 150. That's rediculous. Its not the service. I have the same thing and it works fine, getting almost 3000kbps down, which is max rating on this service. The cables have been switched, the NIC has been switched and switched the slot its in. The PC is a fresh install. I'm thinking it has to be the modem or the main cable in the house.
If you have a laptop, see what kind of speeds you get at home, then take it to her place and see what speeds you get. Sometimes, just resetting the modem / shutting it off for 5 min can make a difference. It could aslo be bad cabling. You may also want to call the cable company and ask what the minimum rated speed is. If you're not getting it, then it's up to them to make sure you are.
Nothing can stop me now, 'cause I don't care anymore. -
if it is DSL , they can , while you are online, test the connection and cable for you .... at least here they are very good about it ... it also happens that they simply have misconfigured thier end as they can adjust speeds .. I had them reduce my speed for a more stable connection
if its cable -- it could be the people next door running a major server or doing a wack of downloading ...
Originally Posted by BJ_M
Not sure about Cable, but I think the download even for the basic plan is supposed to be a minimum of 384K.Nothing can stop me now, 'cause I don't care anymore. -
Yeah I'll have to call their tech support if she hasn't already done so. I've tested mine several times and never gotten below about 1200kbps minimum. Hers is running a max of about 300-350 and as low as 100 at times that I've seen. Thats not right at all. Adelphia is pretty good on their customer service but their local techs are all idiots. I'm sure I can get them to listen on the phone but whoever comes out to look at it could be a different matter.
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 02:30 -
Strange DVD SPEED test results
By tac7 in forum DVD RippingReplies: 5Last Post: 2nd Apr 2009, 21:24 -
Speed Test Results
By HmNtr in forum Off topicReplies: 0Last Post: 28th Dec 2008, 01:58 -
converting to AVI or mp4 with stand alond dvd recorder..speed test
By diablo_ogre in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2008, 09:55 -
Comcast speed test.
By Poppa_Meth in forum ComputerReplies: 7Last Post: 27th Aug 2007, 09:28
